Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Wheel Horse 244-5 won't crank
El Toro
06-07-2013 07:32:07
It should at least crank over the engine when he jumpered at the starter. Hal
joe csuti
06-07-2013 13:17:55
 Re: Wheel Horse 244-5 won't crank in reply to El Toro, 06-07-2013 07:32:07
Hi Hal-The sol on his eng is mounted on starter & is a plunger/lifting fork design to lift drive into flywheel ring gear in addition to closeing contacts for starter motor,he probably took jumper to battery terminal on sol rather than jumping to terminal on sol that has tab on it going into starter motor,doing this would at least cause starter motor to spin,but drive won't engage flywheel,to get starter to engage normally all he has to do is take a jumper to coil terminal on sol,if he has power to starter & sol/starter in working condition starter will spin eng,there are also two 25A fuses on tractor,one for alt output & the other for wiring on tractor(ign sw,pto,lights).
