TractorLinks.com
Re: Wheel Horse 244-5 won't crank
El Toro
06-06-2013 14:24:29
You should remove the ground cable and clean all battery cable connections until they're shiny. Clean the surface where your battery is grounded
that includes all the lugs/spades on your battery cables. If there's a starter solenoid clean those cables too. Use a hydrometer and check the specific gravity in each battery cell. Should see readings around 1.280 on a fully charged battery. If none of these fix the problem pull the starter and see if the bendix drive will move when you apply battery voltage. It should fly out when voltage is applied to engage the ring gear. Keep your hands and fingers away that end of the starter. Hal
Edd In KY
06-06-2013 14:44:16
 Re: Wheel Horse 244-5 won't crank in reply to El Toro, 06-06-2013 14:24:29
Thanks, Now I at least know where to start.
