kawaski 17 h.p alternator wiring
Anonymous-0
come off j.d. lawn mower. I am putting on cart.has 5 wires coming out of motor.two to electronic modual.three for alternator two blacks. one white. how do you mearsue output of alternator? which & where do you connect wires. thanks for any help. regards Dick
What tractor is it out of... might be able to find a diagram of the whole tractor.
Bob..j.d. model 262..K series 17.h.p. code f.c.540V-E500 E/no f.c.540 v189852 made in Japan thanks again Dick
Do a goggle search for john deere 265+wiring diagram,from 4 drawings in row in search,click on 2nd pic from left,read posting/reply & look at wiring diag,rectifer/regulator probably remote mounted on tractor frame,look at wire colors at reg & see if they match colors in diag,if they do 2 blk wires are alt stator output(ac) & red wire on reg DC for charging battery,this reg also has a voltage/current sensor to light a battery discharge lite,internally in reg the output from reg may/may not disconnect from battery to protect reg/alt stator if battery discharge lite comes on,you may have to use oem reg to get charging system to operate correctly.
