Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD LX178Engine Stalling
El Toro
06-02-2013 10:24:34
You need to get a wiring diagram of your tractor's electrical system. You may have a stator with a rectifier/regulator. Your battery voltage drop is probably causing your engine stalling. Using a volt meter set on dc volts and the engine at 1/2 throttle or better you should see 14-14.5 volts across your battery terminals.
Could be a diode used in the charging circuit. Your JD dealer may give you a copy of the wiring diagram. I have them for the 317 and 318 JD's. Hal
jeffcat
06-02-2013 14:46:03
 Re: JD LX178Engine Stalling in reply to El Toro, 06-02-2013 10:24:34
My two cents. Go on Ebay and enter you tractor in the search. You can pick up a CD with PDF files with all of the manuals you need for your tractor. About $15.oo for cost and shipping. Jeffcat
Copyright © 1997-2015 Yesterday's Tractor Co.
