TractorLinks.com
Re: Ford LGT100
Indiana Ken
06-02-2013 05:39:43
Is the idler pulley you need mounted on the mower deck or part of the mower drive system and mounted on the tractor? The mowers I have to check for you are a LT 75 which is a 8HP vertical shaft; it uses a short belt from the engine to a jack shaft, the mower drive belt then attaches to the bottom end of the jack shaft to drive the mower blades. The mower deck has two blades...I think (?) this is similar to the LT 100. I also have a LGT 16 which is a horizon shaft engine with an electric clutch for the mower drive. The deck has 3 blades. I can get the pulley sizes for you once I am clear on which pulley.
