Kohler K181 starting problem
Butch(OH)
Hi,
I have a model 86 Cub Cadet with newly rebuilt K181 Kohler that kicks back against the starter when it fires. This is not a compression release problem, it cranks fine until it fires and when it does it kicks back hard against the starter. Lacking a timing light where it is used I closed the point gap up to retard the timing and the problem did not change. Now have it at the shop and checked the timing and it is a few degrees late. Advancing it to the proper setting of course makes the problem worse. With the points set to only .010 the timing mark is at the top of the window when the points open or quite a bit late. It kicks back hard enough to stop the starter and after 3-4 times it will finaly go past TDC and run. Anyone care to throw some guesses at this??
Thanks in advance.
Sounds like you might possibly have the cam and crank out of time one tooth. Just something to ponder. Dave
OK, went out and found TDC and then looked in the ting hole and the mark was dead center, I think that eliminates a sheared key? Thanks for the suggestion.
if the valve lash is close,both valves should be at the same height when the piston is at top dead center.i put lots of cranks and cams together that have no timing marks on them.
The older models used a different cam with spark advance rather than ACR. A stuck advance would act like yours does. Are you SURE you have ACR rather than spark advance?
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/Kohler/K-181_zpsf2b95a64.jpg">
