Yesterday's Tractor Co.
Shop Now View Cart
Re: compression!!!
joe csuti
05-31-2013 03:22:29
If you're rotating eng to top tdc of compression stroke(both valves closed)then dropping piston 1/4" & setting clearances,then you're doing same correctly,I'm also assumeing whatever manual/spec sheet you're looking at calls for .003"-.005" on intake & .005"-.007" on exh,then you're setting valves correctly,a lot of guys like to set both for .004" on both to make for a longer time between adjustments,you might try that.
If carb not leaking other possible cause's of problem,if cam gear plastic,gear may be worn or bearings for cam worn & cam jumped it's time,acr cam worn or one of the pushrods may be bent.
05-31-2013 14:56:38
 Re: compression!!! in reply to joe csuti, 05-31-2013 03:22:29
just re-set valves for third time, set both at.04 1/4 inch down after tdc. checked both push rods and neither one bent, put it back together, and a lot better now. every once in a while it will still hang and not crank past compression, but most of the time it will start right up. if it hangs, i just roll it backwards a turn or two then hit it and it will start. I am guessing valves still not set just perfect but i can live with that. at least i can get it started now pretty easy. thanks for all the responses, it really helped a lot!
05-31-2013 14:59:30
 Re: compression!!! in reply to bdunegan, 05-31-2013 14:56:38
OOPS! meant .004. Thanks again
