Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Cub Cadet 124 Runs Good, Knocks, Then DIES!
joe csuti
05-27-2013 02:53:33
IF you have to use choke from time to time to keep eng running this points to a fuel supply problem in addition to possible sticking valve(s) or a leaking head gasket.
Check out the fuel system,look for plugged/restricted filter,plugged restricted or bad hose between tank/pump,plugged outlet on tank,bad/plugged gas shutoff valve(if tractor has),plugged/bad vent cap on tank,weak/bad fuel pump,dirt/water in carb bowl & internal passages of carb body,sticking/bad float,sticking/worn float needle/seat,dirt in float needle seat hole,loose carb or bad mounting gasket for carb.
Copyright © 1997-2015 Yesterday's Tractor Co.
