TractorLinks.com
Re: Cub Cadet 124 Runs Good, Knocks, Then DIES!
RTR
05-24-2013 17:20:18
What would be an effective easy fix to this? Adding some MMO to the gas ? I actually filled the tank with a half gallon of gas and put a quarter pint of MMO in the gas. That s what I have ran it on since I got it running.
joe csuti
05-25-2013 03:28:45
 Re: Cub Cadet 124 Runs Good, Knocks, Then DIES! in reply to RTR, 05-24-2013 17:20:18
I've had carbon problem on valve stems on two eng(both tired & burning oil)I've also never had much luck with Marvel & other oil/gas additives when you have this condition as carbon buildup becomes quite hard & usually requires sandpaper/wire brush to remove,in addition there may also be rust on stems if eng sat for an extended time,easist/quickest cure I found was pull head & remove valve keeper/springs & remove valves and clean stems,depending on how much carbon/rust on stem this may have you talking to yourself & nasty to eng depending on how difficult it is to work valve back/forth thru guide till same can be removed from eng.
