Yesterday's Tractor Co.
Shop Now View Cart
Re: Kohler KT17 Smoking
Brian Dan
05-22-2013 19:14:28
Check your air filter and see if it is full of enging oil. If it is you will need to replace a breather valve. The breather valve is located under the air cleaner, follow the tube from the air cleaner to valve cover. Also if the valve is bad your engine will blow the oil seal on the crank out put shaft.
05-22-2013 21:13:45
 Re: Kohler KT17 Smoking in reply to Brian Dan, 05-22-2013 19:14:28
The air cleaner is mounted on the carb with no breather tube going to it. I"ll. have to follow the tube and see where the other end goes to. I think I remember it going to a square plate that was held on with a bolt in the center of it. Does that sound familiar?
