I have a mower with horizontal opposed twin II. Just mowing along and started wanting to die. isolated to intermittent spark by using a light tester. Gap to the magnet and top part of coil is next to nothing. However, I can move the flywheel or crank and get about .005 clearance. My guess is the play in the crank bearing is causing contact and killing spark.
Question is should I adjust and run it or since this happened suddenly, assume that bearing is going way south? Is this normal? Would contact of the coil certainly kill spark?
