TractorLinks.com
Re: JD 112 No Fuel to Carb? HH 100 Tecumseh
BillM2
05-16-2013 19:34:25
Is there a diagram of this carb somewhere?
I did take the bowl off, let the float hang, and cranked the engine. No gas flowed. I'm soaking the carb overnight to see if that frees up
Anything.
joe csuti
05-17-2013 03:19:26
 Re: JD 112 No Fuel to Carb? HH 100 Tecumseh in reply to BillM2, 05-16-2013 19:34:25
If the float needle is still connected to tang on float by small clip & drops with float,then the problem is as has been said-hole in float needle seat plugged or seat damaged,if needle disconnected from float then needle stuck in seat due to dirt/gum or the more common cause,needle seat age hardned/distorted & needle sticking in seat,the only cure for this problem is replace needle/seat.
For assembly drawing of carb goto link below & lookup mod/spec# in tecumseh eng parts listing.
IF you have to remove seat from needle bore hole use a long #4 sheetmetal or wood screw & thread into hole in seat & pull seat out of bore,if you do pull out you will need a new seat as seat will be damaged when removing.
BillM2
06-10-2013 14:05:11
 Re: JD 112 No Fuel to Carb? HH 100 Tecumseh in reply to joe csuti, 05-17-2013 03:19:26
So I cleaned thoroughly and got the engine to run. I may have gotten some fuel line rubber in the carb (I've replaced the old one) because now the engine surges. Or is an adjustment needed? When I engage the mower's belts, it doesn't surge. Any further advice?
