TractorLinks.com
Re: JD 112 No Fuel to Carb? HH 100 Tecumseh
BillM2
05-16-2013 07:22:43
Thanks! I can locate no fuel pump anywhere on the engine. I was told it might be a gravity fed set-up. The float moves freely. I may again soak the carb but this time overnight and see if that does something.
Not sure if I understand how to add a fuel pump and why one would be needed given it was running without one for years?
Keep the suggestions flowing -- unlike my fuel.
rrobert
05-16-2013 07:46:35
 Re: JD 112 No Fuel to Carb? HH 100 Tecumseh in reply to BillM2, 05-16-2013 07:22:43
Yah, if it doesn't have a fuel pump, then no need to add one.
Did you remove the rubber seat before you soaked the carb? It might have swollen or could be slipped out of place. Sometimes they will drop and not let fuel thru.
Did you check for an on/off valve on the tank?
