JD 455 oil light
Anonymous-0
I just purchased a JD 455 this spring. I did the yearly maintance kit. After mowing in the dark the other night I noticed the oil light comes on at idle. It will go off when I add throttle. Is this anything I should be worried about?
I don't know if this is your problem you might change oil filter. Had a car do this after oil change with Fram filter ( first time useing Fram). I put a Wix on it and it was fine. You might check sending unit.
