Case 446 speed control
Kirk-Tx
Hydraulic speed control lever will not stay in place. We shimmed the spring to make tighter but didn't help. I feel the notches but they have to be worn. Where is the best place to find the plastic or nylon bushing? Thanks Kirk
Contact this guy:
[email protected]
Brian is an Ingersoll(Case) dealer and had been good to deal with for me. Fair prices/ships quickly. He'll need your PIN from the tractor tag to get the right part for you. There are several variations of that part through the years.
they really were never ment to hold on their own in a spot other than the full open position, they make a flow control valve that allows you to set it from a complete crawl to wide open by moving a lever, they cost but it will then do what you are wanting it to do every time
Case Nutty, It will not stay in full speed. It always slows down if I don't hold it. I was thinking something may be worn. Thanks
