Honda 24hp Vtwin charging problem
geok
Have a ZTR with a Honda 670 24hp Vtwin. It quit charging the battery so I bought a new rectifier for it. After installing it I checked the voltage on the battery and at an idle it was showing 14.5 volts. After I reved up the engine. It quit charging and I may have just wasted a new rectifier. Pricey. Any idea where I might start looking for the problem?
Use a volt meter and check the ac voltage to your rectifier. Should be around 30 volts. Run the engine at 1/2 throttle or better. Hal
