TractorLinks.com
Re: not a lawn tractor but a snowblower....
dennis min
04-29-2013 16:53:41
hope these come through...
joe csuti
05-01-2013 17:45:19
 Re: not a lawn tractor but a snowblower.... in reply to dennis min, 04-29-2013 16:53:41
Looking at muffler,carb & starter in pics,eng is a tecumseh,it also appears that coil,points/condenser(if eng has)are located under flywheel.
In addition you may have an 18w alternator stator under flywheel,in one pic blk wire coming out of flywheel backplate & going up handle could be for a key sw/stop sw on handle cross bar or an 18w sealbeam lite as I have on mine,I don't know which you have on yours.
In one pic of flywheel cover/recoil starter(bottom view) there are two small holes,this is normally where id tag is located either tag never put on,lost/removed or may have been a decal that's long gone.
dennis min
05-02-2013 15:31:18
 Re: not a lawn tractor but a snowblower.... in reply to joe csuti, 05-01-2013 17:45:19
Joe,
thanks for looking and keeping me in the loop. It does indeed have a headlight.
I guess I"m in for pulling hte flywheel to see what can be seen.
I was thinking of timing, but on a thrower, how would it get off? There"s shear pins, belts to keep the crankshaft from getting jarred and shearing a key?
I am stumped on this, but appreciate all the help.
D.
joe csuti
05-02-2013 16:24:31
 Re: not a lawn tractor but a snowblower.... in reply to dennis min, 05-02-2013 15:31:18
The ign timing is determined by position of flywheel on crankshaft,the shaft key on crankshaft holds timing of flywheel & ign,if shaft key Z bent or sheared & flywheel moves on crank this will change ign timing,2-3 degrees in either direction(retarded or advanced)and eng may not/won't run due to plug fireing either too early/late.This is why I said to check flywheel key in another reply.
joe csuti
05-02-2013 16:38:41
 Re: not a lawn tractor but a snowblower.... in reply to joe csuti, 05-02-2013 16:24:31
Forgot to add,flywheel key is made of soft aluminum not steel,due to sheer age,vibration,causeing eng to stop suddenly by overloading blower,something caught in auger/impeller or a loose flywheel nut all of the above take their toll on key over the yrs.
DENNIS MIN
05-02-2013 17:56:01
 Re: not a lawn tractor but a snowblower.... in reply to joe csuti, 05-02-2013 16:38:41
Joe,
I hope you don"t mind responding to my questions...
I am going to pull the flywheel and am going to post some pictures.
Again, thanks for all your help.
D.
