TractorLinks.com
Re: JD 425 hydraulics
Dan50
04-29-2013 05:42:53
JD Seller -I'm that guy that washes my tractor off a lot. That may explain why that spool is locked up.
Ken- Thanks for that catch on the lockout valve. You saved me some money too! Looks like I'll be going that way on the valve.
Along with a little welding and painting, this should make for a little project this summer.
Any ideas for an alternative for those pricey suitcase weights and bracket for the rear? Or should I just bite the bullet on that? Thanks guys.
JD Seller
04-29-2013 07:59:54
 Re: JD 425 hydraulics in reply to Dan50, 04-29-2013 05:42:53
Just fill the rear tires with washer fluid. You will get about 7-8 gallons in each wheel. Just take the tire off and break the top bead down and pour the washer fluid in. Also you can get wheel weights.
The advantage of weights in the wheels is that you trans-axle does not have to carry the additional weight on the axles and bearings.
