Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: not a lawn tractor but a snowblower....
DENNIS MIN
04-28-2013 16:06:55
GBMN, I am sure htere are no umbers on the sheetmetal housing thaat also has the recoil.
I don"t know where else to look.
D.
joe csuti
04-28-2013 18:28:25
 Re: not a lawn tractor but a snowblower.... in reply to DENNIS MIN, 04-28-2013 16:06:55
Your snowblower was made by AMF & same/similar to craftsman 26" blower I have(7hp)as mine was also made by AMF,GBMN is correct eng probably a Tecumseh(H80).
Look on side of recoil starter houseing below heat box cover for carb,there should be a craftsman id tag riveted to houseing,stamped in tag will be sears mod# for eng,spec# & sn,if mod# starts with 143 then eng a tecumseh,if mod# starts with 500 then eng a briggs.IF there are only 2 holes in starter houseing below heat box then either rivets broke & tag fell off or someone removed tag,either way it's gone.
This is an old snowblower probably mid 70's-early 80's,the ign may be point type of solid state as there was a change over in above time frame(bought mine used & never had a problem with ign,so I don't know if point type or solid state ign,never had flywheel cover off)remove flywheel cover,you'll probably find coil mounted over flywheel,IF there is a wire going from terminal on coil to under flywheel,then you have point type ign,if only a single wire connected to coil going to key sw on heat box cover then ign is solid state & has no points/condenser.
Copyright © 1997-2015 Yesterday's Tractor Co.
