Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: not a lawn tractor but a snowblower....
DENNIS MIN
04-28-2013 07:36:22
I apologize for not getting enough info on here.
The engine is on a craftsman snowthrower. It"s a horizontal shaft, 8 hp. 26 inch cut.
model# 536_918400
serial# 9138.
Things I did: drained old gas, put in new. New spark plug. Tried to start with ether- did not pop. Romoved plug, was wetted with gas. Placed plug on the head and saw spark, which I thought was weak, but present.
Took compression tester and got it to reaad 115 psi.
Don"t know where to go from here...
D.
MNGB
04-28-2013 09:24:28
 Re: not a lawn tractor but a snowblower.... in reply to DENNIS MIN, 04-28-2013 07:36:22
If the spark is weak the plug may not be firing under compression is this a Tecumseh engine and does it have electronic or magneto ignition? Have you tried pouring some gas in the carb and cranking it?
GB in MN
This post was edited by MNGB at 09:25:44 04/28/13.
dennis min
04-28-2013 10:15:12
 Re: not a lawn tractor but a snowblower.... in reply to MNGB, 04-28-2013 09:24:28
MNGB:
I trie a new plug, which didn't hellp. I don't know if it's atecumseh, there's no markings onthe recils cover.
I believe it's plenty old not to have electronic ignition. It looks that thte electrical is under the flywheel, if that helps.
Thanks for he response,
D.
MNGB
04-28-2013 10:34:39
 Re: not a lawn tractor but a snowblower.... in reply to dennis min, 04-28-2013 10:15:12
If it has a magneto the points maybe corroded and the condenser could be bad you could try cleaning the points or installing new points and condenser, and see if you get a strong spark.
GB in MN
dennis min
04-28-2013 10:58:09
 Re: not a lawn tractor but a snowblower.... in reply to MNGB, 04-28-2013 10:34:39
MNGB,
Perhaps you could enlightne me on small engines.
The magneto/points are under the flywheel?
Thanks,
D.
MNGB
04-28-2013 14:59:44
 Re: not a lawn tractor but a snowblower.... in reply to dennis min, 04-28-2013 10:58:09
Hi Dennis, yes most of the older engines have the coil outside the flywheel generally at the top and the points and condenser are mount under the flywheel, which requires removing the flywheel to get at them. I can't be more specific with out know the engine make and model, I'm thinking Tecumseh as Sears used them on a lot of their power equipment. On the cooling housing there will be numbers for model etc try locating them.
GB in MN
DENNIS MIN
04-28-2013 16:06:55
 Re: not a lawn tractor but a snowblower.... in reply to MNGB, 04-28-2013 14:59:44
GBMN, I am sure htere are no umbers on the sheetmetal housing thaat also has the recoil.
I don"t know where else to look.
D.
joe csuti
04-28-2013 18:28:25
 Re: not a lawn tractor but a snowblower.... in reply to DENNIS MIN, 04-28-2013 16:06:55
Your snowblower was made by AMF & same/similar to craftsman 26" blower I have(7hp)as mine was also made by AMF,GBMN is correct eng probably a Tecumseh(H80).
Look on side of recoil starter houseing below heat box cover for carb,there should be a craftsman id tag riveted to houseing,stamped in tag will be sears mod# for eng,spec# & sn,if mod# starts with 143 then eng a tecumseh,if mod# starts with 500 then eng a briggs.IF there are only 2 holes in starter houseing below heat box then either rivets broke & tag fell off or someone removed tag,either way it's gone.
This is an old snowblower probably mid 70's-early 80's,the ign may be point type of solid state as there was a change over in above time frame(bought mine used & never had a problem with ign,so I don't know if point type or solid state ign,never had flywheel cover off)remove flywheel cover,you'll probably find coil mounted over flywheel,IF there is a wire going from terminal on coil to under flywheel,then you have point type ign,if only a single wire connected to coil going to key sw on heat box cover then ign is solid state & has no points/condenser.
