Anonymous-0
I have a B&S 24 hp Intek 2 cylinder OHV engine that started to backfire. When checking the engine I found the intake pushrod bent and the exhaust pushrod was gone. Also the valve guide on the exhaust valve appears to be comming out of the head.
Questions, Did the pushrod go into the engine? Where? Is disassembly of engine necessary to get it out?
About the valve guide. How to repair so it will stay in the head? Is a new head the only way to fix the valve guide problem?
Thanks in advance for all your responses, ideas, and wisdom. Bud
