Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD 425 All Wheel Steer - Will snow blade work OK on this?
JD Seller
04-13-2013 07:49:46
The other guys have it nail as far as spacers and such. To use the older blades off of the JD 300 series all you have to do is widen the mount. The latch is the same distance top to bottom but the frame is about 1 inch too narrow. Cut the latch plates off the old blade and put steel flat stock behind them and re-weld them. I think 1/2 inch on each side is what it takes. I have done several but it was 5 year ago or more. Then you just need longer hydraulic hoses to reach the valve under the foot pad.
Copyright © 1997-2015 Yesterday's Tractor Co.
