Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Case 220 problem
Tom Arnold
03-30-2013 14:05:23
There is no filter.
If you did not install 15W40 or 20W50 MOTOR OIL in your hydraulic reservoir, that is most likely the problem. Remove the drain plug on the underside of the travel valve and run the tractor long enough to pump out all the oil. When you see it spurt air, shut the engine off.
I'm betting that you put hydraulic oil into it. That's a mistake.
