TractorLinks.com
Re: Seal removal procedure technique
El Toro
03-29-2013 17:18:31
I had to replace the seals on our Troy Bilt tiller. On the one side I drilled a small hole and threaded a screw into the hole that was attached to a sliding bar puller. First I had to drain all the oil. The other side had small cap screws and I removed the cover. Then I used a brass drift to remove the old seal and tapped in the new seal. This is behind the tine holders
and you need to remove them and a long 1/2" cap screw to gain access to the seals. Hal
