the b@s 5hp engune
Anonymous-0
sorry for the lack imfo the model no 135203 the type 0258-01 code 960119ye and one other thing on this carb @tank when remove carb from tank there is asteel ball in the tank right under carb is it suppose float or stay on bottom or top thanks againhave a bles dat
Briggs used two different style fuel pickup systems for carb with side mounted pump used on your eng.One system had a single pickup tube either brass/plastic with a filter screen on bottom of same,some of these had a ball check valve in tube above screen,if screen damaged/missing ball in bottom of tank may be from tube,in which case pickup tube assembly will have to be replaced.
The second system is a two pipe pickup(1 long,1 short)pickups may be brass/plastic each with a filter screen & possibly a check ball in one/both pipes,in this system the tank has a reserve well welded into top of tank that short tube goes into when carb is mounted on tank,if ball you're talking about is in this well,then it might be check ball from pickup tube,in operation pump pulls gas from tank thru long tube & pumps into well,short pickup pulls gas from well to feed main jet in carb,any excess gas from pump just overflows back into tank after well full.
Another thing to check,remove cover from fuel pump & confirm that pump return spring/cap are installed in cavity in carb BODY side of pump diaphram and NOT in cavity of pump cover(easy to do,been there done it)also while pump apart check that vac passage between pump body & carb venturi not plugged/gummed up,run a fine wire thru same then blow out with compressed air.Check that pump body not warped or pump cover not warped allowing pump to suck air.
Also check brass/plastic tubes for splits/cracks & also that tube(s) are tight in carb body.
You might want to pickup a service/repair manual(pn270962) for your eng from local dealer,briggs website or ebay,manual will have service instructions for both types of carbs.
thanks for the imfo. men i have not tride any of it yet my oldes son past away the 26th this past month he was 49 . iam just now getting back in the shop working so i well use the imfo . so thank again god bless
and try the trimmer again
on the 5hp b@s engine i replace the pick up tube in the tank the long tube now it running fine thanks for your help god bless
