Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Stabley garden tractor running on one cylinder
Gene Davis (Ga.)
03-20-2013 17:02:06
Some of these engines har trouble with the valve pushrods bending and not opening the valves which caused a skip. Pull off one plug wire at a time until it quits and that will find you the dead cylinder. Check for spark also as some had one coil to go bad and still run on the other cylinder.
Blackriver
03-21-2013 17:34:48
 Re: Stabley garden tractor running on one cylinder in reply to Gene Davis (Ga.), 03-20-2013 17:02:06
I've tried to answer three times but can't seem to get the site to work for me. It was the left cylinder, i had fire to both sides, but the rocker arms on the left had got so loose one of the push rods had come loose. The other was bent, i staightened it out the best i could and tightened both back up. It runs pretty good now. Thanks for the help.
Copyright © 1997-2015 Yesterday's Tractor Co.
