TractorLinks.com
Re: Can I put an elec. starter on a 5hp I/C Briggs?
ShadetreeRet
03-10-2013 22:37:21
I don't know if all Briggs flywheels have teeth or not, Tecumseh/Craftsman did for years, but if you are able to put a stater on it, you will have to use a charger to keep the battery charged as there is no charging system on your engine. The way you describe it, I assume that it has the carburetor attached to the fuel tank. If so, and since it has had water in it, have you replaced the fuel pump diaphragm? Have you either soaked the carb in cleaner or sprayed cleaner in all passages and blew them out with compressed air? Just some thoughts.
