Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: El Toro
El Toro
03-02-2013 07:09:52
Run a heavy wire directly from your battery to the starter to see if the engine spins over. Be careful where your fingers are. Some of those solenoids need to be grounded during the initial start. My Wards tractor has pedal that needs to be depressed before the engine will crank. Once the engine starts you remove your foot off the pedal. There should be a battery cable that runs from the solenoid to your starter. It should only have voltage when making an engine start. Use a volt meter to check for voltage. You will probably need a helper. Hal
Copyright © 1997-2015 Yesterday's Tractor Co.
