TractorLinks.com
Re: 682 CC Kohler KT17
Ken-Pa
02-28-2013 21:50:27
I bought a Cub Cadet 1711 a couple years ago that had a KT17 Hydro in it . The first time i used it to mow my yard (which has banks in it) the engine blew sky hi . The inside of the engine is trashed . By asking a lot of questions 7 studying info off Google , I learned that Cub Cadet engineering dept made a very bad mistake in their engine designs . They used an oil slinger system instead of an oil pump & filtering system . The even sent out warnings to dealers to advise owners not to run them on hilly areas because the oil wouldn't get to the crank, rods & bearing causing major damage . The guy that sold it to me didn't tell me anything at all & chucled when I called & told him about it . So, I hope you don't experience the same issue . God bless , Ken
Bob
02-28-2013 22:39:01
 Re: 682 CC Kohler KT17 in reply to Ken-Pa, 02-28-2013 21:50:27
ACTUALLY, that engine HAS an oil pump with a pickup screen. The main crankshaft bearings and hollow CAMSHAFT are pressure-lubed. The camshaft sits above the crankshaft. The cam is hollow and has oil holes in it that spray oil on the connecting rod bearings from above!
TWheat
03-01-2013 02:47:39
 Re: 682 CC Kohler KT17 in reply to Bob, 02-28-2013 22:39:01
The Series 1 engines were/are slinger lubed, the Series11 were/are pressure lubed.
Not 100% reliabale because of owner changes, but the air filter cover is marked as to whether Series 1 or 11.
I have a Series 11 that was overhauled at 2200 hours and has 600 hours on the rebuild.
Kmo
03-01-2013 05:50:47
 Re: 682 CC Kohler KT17 in reply to TWheat, 03-01-2013 02:47:39
I don't trust the air cleaner, I check the engine spec number. The Series I spec number is 24193 and the series II is 24302.
dcpuller
03-01-2013 13:02:09
 Re: 682 CC Kohler KT17 in reply to Kmo, 03-01-2013 05:50:47
Thanks for the info. I'm picking up a 782 tommorrow, belive it's a series 1 but will check. Got it for a good price including a 44 inch deck, 3 pt hitch, and one bottom plow.
