Yesterday's Tractor Co.
Shop Now View Cart
Re: Case 224 won't start
Harvey 2
02-26-2013 13:57:36
Either change the ignition switch to a battery switch, or trace the wires to see if they are hooked up correctly.
The symptoms you describe indicates its a magneto switch and not a battery switch.
Tom Arnold
02-26-2013 15:11:36
 Re: Case 224 won't start in reply to Harvey 2, 02-26-2013 13:57:36
Harvey, If the tractor ran fine at one point with this switch in the dash, then it isn't a switch designed for magneto ignitions that ground out the mag. It's just a switch that has failed due to wear and tear.
Harvey 2
02-26-2013 16:57:30
 Re: Case 224 won't start in reply to Tom Arnold, 02-26-2013 15:11:36
You are right, the switch is probably wore out.
I have bought garden tractors that had the wrong switch on them.
I had one that would start when I turned loose of the key, but it was in good condition and the spinning of the engine after I turned loose of the key it would start.
