Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: Case 224 won't start
[Show Entire Topic]  [Return to Forum]
Harvey 2
02-26-2013 11:45:33
74.128.149.135
Sounds like it has the wrong kind of ignition switch. Is the tractor battery ignition, with points? It should be. If it is make sure that you get a switch that is for battery ignition and not magneto ignition.
A batter ignition switch provides fire to the coil and a magneto switch grounds out the mag.
[Reply]   [No Email]
Don V
02-26-2013 12:32:07
71.63.25.148
 Re: Case 224 won't start in reply to Harvey 2, 02-26-2013 11:45:33
Harvey: It is battery ignition with points. It cranked and ran fine when I first got it. With the ignition in on position I get fire to the points but when I engage the starter there is no fire to points or plug. With the starter disengaged and the ignition on with the engine still drifting to a stop, I have fire to the points and the plug.
[Reply]  [No Email]
Harvey 2
02-26-2013 13:57:36
74.128.149.135
 Re: Case 224 won't start in reply to Don V, 02-26-2013 12:32:07
Either change the ignition switch to a battery switch, or trace the wires to see if they are hooked up correctly.
The symptoms you describe indicates its a magneto switch and not a battery switch.
[Reply]  [No Email]
Tom Arnold
02-26-2013 15:11:36
174.95.11.66
 Re: Case 224 won't start in reply to Harvey 2, 02-26-2013 13:57:36
Harvey,
If the tractor ran fine at one point with this switch in the dash, then it isn't a switch designed for magneto ignitions that ground out the mag. It's just a switch that has failed due to wear and tear.
[Reply]  [No Email]
Harvey 2
02-26-2013 16:57:30
74.128.149.135
 Re: Case 224 won't start in reply to Tom Arnold, 02-26-2013 15:11:36
You are right, the switch is probably wore out.
I have bought garden tractors that had the wrong switch on them.
I had one that would start when I turned loose of the key, but it was in good condition and the spinning of the engine after I turned loose of the key it would start.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
