Gravely Tractor
I have been working on (3) Gravely Tractors, and have (1) working to throw snow. (1) my oldest is/was disassembled complete, and near finished, and the parts Gravely near finished. The parts Gravely I tried to start, but it will not stay going. Checked spark and it was orange, timing rechecked, it is getting gas, and the plug gets wet. Can anyone tell me what I may have over looked? Thank you.
Bob
Pull off the plug wire and hold it away from the plug about 1/4" while a helper cranks over the engine. Should see a hot blue spark. Your coil may be getting weak. Hal
Hi Hal,
I thought that I read somewhere the spark was suppose to be a strong blue. Will let you know how it turns out. Thank you.
Hi Ray,
It starts, but seems as though I have to choke it to keep it going. Then once it starts it will only stay going at the most (3) seconds. I do take the choke off. Thank you for your response.
Bob
If this is an L series walk behind goto link below(site has changed)click on manuals on right side of pg,from sub catogory pick walk behind,problem could be carb which others have said,depending on mod of zenith carb,some had a poppet valve in carb body,if this valve stuck open/closed it can cause problem you have,problem could also be in ign system or a combination of both,check at site & see if a service manual listed your mod carb & make/mod mag on eng.
gravely
Gravelys take awhile to warm up to operating temperature before they will run well without the choke in cold weather. That's true even on the best tuned up machine. Try leaving the choke on about half way for a little while.
Make sure your main jet adjustment isn't too rich. Do you have the cast iron or aluminum Zenith?
Ben W.
Hi Ben,
I am in a heated garage, and will be working on it soon again. First thing will be to check that magneto coil, and make sure it has the proper ohms, and check out tha condenser. Thank you.
Bob
