TractorLinks.com
Re: Gravely Tractor
ray hofstetter
02-25-2013 17:20:55
Plug wet after it quits? Too much gas flooding it out....check that the choke is opening and/or carb float...
Farmall Bob
02-25-2013 23:34:49
 Re: Gravely Tractor in reply to ray hofstetter, 02-25-2013 17:20:55
Hi Ray,
It starts, but seems as though I have to choke it to keep it going. Then once it starts it will only stay going at the most (3) seconds. I do take the choke off. Thank you for your response.
Bob
SuperABen
02-26-2013 06:06:26
 Re: Gravely Tractor in reply to Farmall Bob, 02-25-2013 23:34:49
Gravelys take awhile to warm up to operating temperature before they will run well without the choke in cold weather. That's true even on the best tuned up machine. Try leaving the choke on about half way for a little while.
Make sure your main jet adjustment isn't too rich. Do you have the cast iron or aluminum Zenith?
Ben W.
Farmall Bob
02-26-2013 10:24:51
 Re: Gravely Tractor in reply to SuperABen, 02-26-2013 06:06:26
Hi Ben,
I am in a heated garage, and will be working on it soon again. First thing will be to check that magneto coil, and make sure it has the proper ohms, and check out tha condenser. Thank you.
Bob
