TractorLinks.com
Re: clutch problems on 1961 cub cadet original
88-1175
02-18-2013 10:41:59
if the driveshaft had no groove in it that the bearing could get hung up on check to see if the pinion is being pushed back into the reduction case,when you push the pedal down the driveshaft is movin back instead of compressing thge spring.if thats the problem a od snapring is at fault...
ron brus
02-18-2013 18:17:48
 Re: clutch problems on 1961 cub cadet original in reply to 88-1175, 02-18-2013 10:41:59
snap ring where? The housing on the throw out bearing moves freely and the bearing itself seems to stay in one place...I thought the bearing moves to the front of the shaft and goes back when you step on the clutch. Doesn't the housing (with grease zerk) go forward when in gear and go back (with bearing) when the clutch is depressed?
