K series sleeve
It shouldn't have a sleeve unless it was bored oversize. As been mentioned over size pistons
should be available. Take it to a good auto machine shop and have them measure the block bore. The crankshaft should be measured too. You may need to have it ground undersize and new connecting rod would be required. Hal
PS: They won't grind it unless it's necessary.
Some of us that pull kohler engines will have the block sleeved. Then bore for piston size. The finish on the kohler block isn't very good when it come's to pulling engines when you turn them over 6500 RPM.
