TractorLinks.com
Re: MTD Statesman Electrial Problem
steve_in_mo
02-10-2013 18:37:07
Kill wire from the engine has to be grounded to kill the engine, and that's done through the ignition switch. If you put 12 volts to that line, you burn out the magneto under the flywheel. IF the engine has been swapped out, you have to get creative.
Whizkidkyus
02-10-2013 18:53:07
 Re: MTD Statesman Electrial Problem in reply to steve_in_mo, 02-10-2013 18:37:07
steve_in_mo,
Thank you . I know that the kill wire has to be grounded to kill the motor and I have thought of running the wire to a switch and the other leg to a ground . I don't want to do this as I like to keep my mowers from looking rigged , but may have to do it. I know that there is a ground wire from switch , but which one is it is my problem / question.
Thank you , Whizkid
steve_in_mo
02-11-2013 08:05:13
 Re: MTD Statesman Electrial Problem in reply to Whizkidkyus, 02-10-2013 18:53:07
Pull the connector off the back of the ignition switch. There should actually be one lug marked G. Go from there and you're golden.
Whizkidkyus
02-11-2013 19:08:16
 Re: MTD Statesman Electrial Problem in reply to steve_in_mo, 02-11-2013 08:05:13
steve_in_mo,
Thank you , your right there should be . I had the switch out yesterday but never thought to chek for that
Whizkid
