Yesterday's Tractor Co.
Shop Now View Cart
Re: 1968 Simplicity 717 Broadmoor Wiring Diagram?
El Toro
02-05-2013 17:41:14
Your S/G is getting is battery voltage once the battery is charged using your battery charger. Use a volt meter set on dc volts measuring across the battery terminals when the engine is at 1/2 throttle or better. Should see around 14 volts or better. If you only see 12 volts your S/G isn't charging. Is that a Delco S/G? I have the same setup on my Wards tractor made by Gilson. Hal
