Anonymous-0
does any one on this forum know where I could find rear wheel seals for an old sears tractor.
I think it is a ss16 circa 1973. someone in the past decided it should be painted black, so there is no means of I.D. it has a 16 hp Briggs engine.
thanks in advance,
Floyd
I buy a lot of parts from NAPA:
If you can get the old seal off without messing it up, they should be able to match it up.
A lot of new seals aren't as thick as the old ones, in that regard I usually put two in place of one.
Hope this helps you out.
I have several Surburbans and buy and sell them.
When I get into a situation like that, I usually pull the seal off and run over to an auto parts store. In most cases, they can measure it and get you an equivalent.
Ben W. in VA
OldPathsEquipment.com
The seal you need has a 1" ID OD= 1.430 and is 1/4" wide one number is 100142TC any bearing house will have them as does Sears Parts Direct. also sold on e bay.
GB in MN
