| Garden Tractors Discussion Forum |
Topic: Generac
[Return to Forum]
| Author |
[Modern View]
| Bill Hazelbakerxads
01-29-2013 08:27:24
50.73.114.130
I know this is not a garden tractor but I have read and respected most opinions on this forum. Have a generac 990 twin cylinder with no spark. Can take the ground off each module and get spark. What to do next? Also what should the gap be from the flywheel to the coil? |
[Reply] [No Email] | |
| t.r.k.
01-29-2013 19:35:27
71.31.64.233
Re: Generac in reply to Bill Hazelbakerxads, 01-29-2013 08:27:24
| | I assume you have a genuine generac engine. Have you tried it with the ground wires connected to each coil and the other end of the wire disconnected from the chassis wiring? If you still have spark, the problem is on the chassis somewhere. If your spark goes away then, its probably the wire shorted/pinched somewhere. Or else the diodes in the circuit. The diodes are probably in the wire under the insulation, but sometimes are in the coils. If its on a generator, some have a stop switch in the electrical panel. Be sure its 'on'. |
| joe csuti
01-29-2013 14:42:35
151.198.126.155
| | If eng a briggs intek v twin or a vanguard v twin the coil air gap is .008"-.012" on both. As far as ign problem,intek & late model vanguard eng use a Y ign kill lead,there is a diode installed in each leg of Y that connect to coils to isolate coils from each other,if one of the diodes go bad it usually takes out both cyl,disconnect the kill lead at each coil,crank eng & check for spark,if you have spark now replace the Y lead.Lead can be ordered thru most briggs dealers,take eng mod/type numbers with you. If eng an early vanguard eng will have a ground block mounted on eng with 3 quick disconnect terminals,disconnect kill lead to each coil from block,crank eng & check for spark,if you have spark now replace block,isolation diodes in block bad. |
| joe csuti
01-29-2013 16:55:06
151.198.126.155
Re: Generac in reply to joe csuti, 01-29-2013 14:42:35
| As a quick followup,before condeming ground block if eng an early vanguard,disconnect lead on ground block to stop sw or ign sw,check operation of sw with an ohmmeter or battery powered test light,sw may be bad. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
