Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: OLD simplicity walk behind garden tractor drive/reverse belt
kevinsstuff
01-28-2013 12:15:36
well to adjust your model v . engage belt (not running) so it is tight . then adjust the bracket with the guides so that there is about 1/8 clearance between belt and guide should be just behind pulley for the top and same for bottom which is further back from pulley. the guides are the small diameter with springght looking ends that are bolted to bracket that r bent at right angles and extend over top of belt. u may have to make new ones. if u get it set right when u release the belt.the guides hold the belt just above the pulley top and bottom
