| Garden Tractors Discussion Forum |
Topic: Onan B48 twin 18h.p.
[Return to Forum]
| Author |
[Modern View]
| ray hofstetter
01-27-2013 14:57:10
198.228.228.166
Runs rough at low rpm, but smooths out at high rpm. Almost trying to backfire, but only one cyl. Any thoughts or suggestions? I've tried about everything, but maybe I'm missing something obvious? |
| kevinsstuff
01-28-2013 10:44:03
66.87.7.102
Re: Onan B48 twin 18h.p. in reply to ray hofstetter, 01-27-2013 14:57:10
| my case 446 16hp b43 did same thing. ended up it had burned up intake valve due to debri blocking air flow around head and clyinder. mine was starter side. do a compression test to see if u have low compression . unlit propane torch also works for manifold leak points should set to .016 gap which is 16 degree timing |
| joe csuti
01-27-2013 17:10:39
70.111.201.218
| | Older onan eng split intake manifolds are prone to developing air leaks due to gasket going bad or loose/broken rivets. To check if manifold sucking air,run eng at idle/slightly above,with a can of carb cleaner & plastic ext tube on nozzle,slowly spray around manifold at joint,if eng speed changes,manifold sucking air due to leaking gasket,if you can pinpoint leak you can plug with red rtv sealer or take manifold apart,drill out rivets & replace with screws,seal split with red rtv sealer or jb weld before reassembling. |
| Old Roy
01-27-2013 19:50:30
71.206.209.119
Re: Onan B48 twin 18h.p. in reply to joe csuti, 01-27-2013 17:10:39
| Joe could this possibly the same with my engine.. don't really run rough like missing , but at less than half throttle (Not under power) it will surge bad.16 hp Onan with load on it runs great! |
| joe csuti
01-28-2013 03:07:56
70.111.202.163
Re: Onan B48 twin 18h.p. in reply to Old Roy, 01-27-2013 19:50:30
| | If your eng an onan(wh used both onan & kohler on 416)the most likely cause of surgeing is intake manifold sucking air at split or idle passages plugged/restricted in carb body,a left field possibility is previous owner was fooling with govenor setup. Try the carb cleaner at split trick 1st,if no change in eng operation then consider disassembling carb,clean out all passages in body with a fine wire after soaking in carb cleaner,then blow out all passages with compressed air,get a kit for carb & rebuild or check on ebay for a new oem/aftermarket carb. A quick & dirty trick you might try(I've had a 50/50 success rate with this method)pour 3-4 oz of seafoam gas treatment into tank & run 1-2 tankfulls of gas thru eng,if no manifold air leaks & eng operation doesn't improve with seafoam then consider cleaning/rebuilding or replaceing carb,you might also want to check on ebay for an eng service manual to check out govenor setup/operation. |
| ray hofstetter
01-27-2013 17:35:18
198.228.228.152
| Joe, That's about the only thing I haven't tried. I've heard that the Onans were prone to that... Other than this problem, this Gravely has been one heck of a good tractor for the last 30 years.... |
| farmerjohninpa
01-27-2013 16:14:02
68.32.24.184
| how are the plugs,if old replace them also check points for burn or gap issue |
| ray hofstetter
01-27-2013 16:19:39
198.228.228.144
Re: Onan B48 twin 18h.p. in reply to farmerjohninpa, 01-27-2013 16:14:02
| New points, condenser, and plugs....no change....timing, right on... |
| BushogPapa
01-28-2013 15:04:07
173.88.51.117
Re: Onan B48 twin 18h.p. in reply to ray hofstetter, 01-27-2013 16:19:39
| Valve clearances been checked..?? Ron.. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
