TractorLinks.com
Re: Montgomery Ward tractor, gilson 33048a?
El Toro
01-26-2013 13:24:14
One of those tillers came with my tractor, but I traded it back to Wards for a rotary mower. It was too heavy for me to install. I always plow then use a Troy Bilt tiller. Hal
Harvey 2
01-26-2013 13:57:03
 Re: Montgomery Ward tractor, gilson 33048a? in reply to El Toro, 01-26-2013 13:24:14
I have some Montgomery Wards, but don't have anything but the mower decks.
Is that a home made hitch in back for the plow? The reason i'm asking, is the bracket on tractor covers up the decal and looks to be stationary. They are good looking tractors when painted up like yours.
On the gear shift models I haven't seen any that has the variable speed pulley still on them, evidently that part didn't last very long.
El Toro
01-27-2013 11:29:52
 Re: Montgomery Ward tractor, gilson 33048a? in reply to Harvey 2, 01-26-2013 13:57:03
The sleeve hitch came with the tractor for lifting and pulling different implements. Hal
PS: It also has a Wards part number.
El Toro
01-27-2013 11:25:51
If you're referring to the sleeve hitch it's connected to a bell crank that's connected to the hydraulic cylinder for raising and lowering implements. Hal
El Toro
01-27-2013 04:52:59
Here's the plow on the walk behind tractor. Hal
El Toro
01-26-2013 19:18:05
The plow is off a Viking walk behind tractor I bought in 1960. When I sold the Viking I kept the plow. To get the plow to work on the Wards tractor I had to make a template of the handles on the Viking. The hardest part was getting the bends the same. The bracket at the rear was copied off the Viking handles and the drawbar is
just of piece of metal bent 90 and welded to the plow bracket. When I first made it I used cap screws for mounting the bracket to the sleeve hitch. That was a pain so I made the bracket to fit the sleeve hitch using one pin.
The hydraulics on the tractor lifts and lowers the plow. Here are few pics of the plow bracket. You can still see the 4 tapped holes on the sleeve hitch. Hal
Harvey 2
01-26-2013 20:30:51
 Re: Montgomery Ward tractor, gilson 33048a? in reply to El Toro, 01-26-2013 19:18:05
Thanks for the pictures of how you made the plow work. Around here where I live there wasn't any Montgomery Ward tractors that I knew of. I have some now and one that Gilson marketed as a Gilson, just painted different color than the Wards
Cooter23
01-26-2013 14:32:02
Very nice looking tractor. Mine is identical. Well, I should say I plan on painting it as nice as you have yours as soon as I finish finding parts.
I do not have the mower attachment. If I can figure out or find the right parts for the tiller maybe I can contact you again regarding a mower attachment.
Thanks for your time and information.
El Toro
01-26-2013 18:48:21
 Re: Montgomery Ward tractor, gilson 33048a? in reply to Cooter23, 01-26-2013 14:32:02
I kept the manual on the tiller. Hal
Cooter23
01-28-2013 05:22:25
 Re: Montgomery Ward tractor, gilson 33048a? in reply to El Toro, 01-26-2013 18:48:21
Wow, you have the manual for the tiller. I do not have the original manual for my tractor but was able to locate a parts list manual for '74 models and newer. I also have a '74-77 Gilson service-maintenance manual. This one contains a section regarding the tiller attachment but not in a lot of detail. Would it be possible to get a copy of your manual somehow? I'd be willing to pay for all copy and shipping expenses if you're interested. I keep looking at your tractor all painted up so nice. One of these days I'll get there. Thanks again for your time. Dave (Wilton, California)
rexbeavers
01-27-2013 04:58:38
how is the pto belt is it loose an sliping an you put the tiller down an it put a little load on it an the pto turns the right speed but the shafts turns slower or it has to be in the gear box on the tiller it sleafi would out the gear box up .but first check the pto belt
Cooter23
01-27-2013 19:18:03
 Re: Montgomery Ward tractor, gilson 33048a? in reply to rexbeavers, 01-27-2013 04:58:38
yes I thought the same thing at first as well. In fact the belt that was on there was to small. Replaced with correct size and still have the problem. Like you say, I think it's in the gear drive. I'm in Sacramento Ca. area. No of any guys that work on these older tractors that are inthis area? Thanks for help.
