JD 455 engine problems
Anonymous-0
I have a 455 diesel that has what I think a sticking injector. It smokes a lot of black smoke and has no power what so ever. It starts and idles fine but will bog down under a load. The tractor has 700hrs. Has anyone out there run in to this problem? From what I read the Yanmars are good engines.
Check both air filters(inner & outer) and change the fuel filter. That just may take care of it.
This mower is brand new to me. I just changed the air filter and runs alot better. Thank You. I do have another question on the bottom of the air filter canister should there be something over the air inlet?
