peerless 80110088 transaxle
matt p
I need the case and shift forks for peerless 8010088 the other number on the case 90970679 If anyone has one would to hear from you!! thanks . the transaxle is off Agtrac YT 18/50 tractor it was built by snapper in 70's . Can you weld the cast aluminun case, the bolts fell out mine and cracked the case when I was changing gears
I think the right welder could weld up your case, would probably be best if it was disassembled and cleaned up first.
