BushogPapa
I have several Bolens 17 and 18 HP Garden Tractors that all get used regular and steady...
The old "QT 17" has an Onan engine and needs either a re-Build kit or a replacement Carburetor..
NAPA does not have the Kits (and WOW, the Prices.!)
Could anyone help me find these parts..??
I cannot get the Needle to work properly..it either wants to Flood or Starve to the point it quits..
I tried an Electric fuel pump and it flooded (4lb)..
I have worked on the Needle TIP and worked it to a good taper, like it should have been. (Rubber tip)..
Any suggestions about another carburetor to use..?
This engine is a REAL Powerhouse..I have the Large-Bore Commercial engine block and want to USE it more..!!!
Thanks..!
Ron.
