| Garden Tractors Discussion Forum |
Topic: Re: Testing Briggs coil/Megafire module?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| joe csuti
01-11-2013 13:55:16
151.198.125.91
Disconnect kill lead to ign sw,crank eng & check for spark,if you have spark now then problem in wiring to ign sw from coil,ign sw bad or problem in safety sw's or wiring harness on tractor.If still no spark with kill lead disconnected,check that connection from megafire module to eng block/chassis is clean/tight.After that check flywheel/coil air gap,manual says .010"-.014" or check instructions for megafire unit,air gap may have to be changed,after that goto link below & read instructions for setting flywheel timing as same is adjustable on 243000 series eng. If after disconnecting kill lead,checking megafire ground connection & flywheel timing & you still have no spark,remove coil & take to one/more local mower shops & have them check in a coil tester,if coil tests ok,then problem may be one of the following: 1-Megafire unit bad due to heat/vibration depending on where same mounted on eng/tractor. 2-Flywheel magnets weak,this is a somewhat common problem on these old briggs eng,might try changeing flywheel/coil air gap if magnets the problem,you might be able to get around weak magnets this way. |
[Reply] [No Email] | |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
