Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Testing Briggs coil/Megafire module?
[Return to Forum]
Aaron SEIA
01-11-2013 04:54:19
67.55.181.151
Have a no spark issue on my AC B110. Has new coil, plug, and Mega Fire module. Is there a way to test any of this, or do I just throw parts at it until it sparks again? Probably doesn't have 10 hours on everything.
AaronSEIA
[Reply]   [No Email]
fredinmo
01-11-2013 21:24:43
71.1.121.109
 Re: Testing Briggs coil/Megafire module? in reply to Aaron SEIA, 01-11-2013 04:54:19
Try reversing the wires on your mega chip some old cast iron briggs have a reverse polarity coil.
[Reply]  [No Email]
El Toro
01-11-2013 14:01:40
108.3.143.30
Touch your magnets with a flatblade screwdriver to see if they have strong magnetism as Joe suggested. Hal.
[Reply]  [No Email]
joe csuti
01-11-2013 13:55:16
151.198.125.91
Disconnect kill lead to ign sw,crank eng & check for spark,if you have spark now then problem in wiring to ign sw from coil,ign sw bad or problem in safety sw's or wiring harness on tractor.
If still no spark with kill lead disconnected,check that connection from megafire module to eng block/chassis is clean/tight.After that check flywheel/coil air gap,manual says .010"-.014" or check instructions for megafire unit,air gap may have to be changed,after that goto link below & read instructions for setting flywheel timing as same is adjustable on 243000 series eng.
If after disconnecting kill lead,checking megafire ground connection & flywheel timing & you still have no spark,remove coil & take to one/more local mower shops & have them check in a coil tester,if coil tests ok,then problem may be one of the following:
1-Megafire unit bad due to heat/vibration depending on where same mounted on eng/tractor.
2-Flywheel magnets weak,this is a somewhat common problem on these old briggs eng,might try changeing flywheel/coil air gap if magnets the problem,you might be able to get around weak magnets this way.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
