TractorLinks.com
Rebuild Onan Carb..????
BushogPapa
01-07-2013 10:12:01
I have several Bolens 17 and 18 HP Garden Tractors that all get used regular and steady...
The old "QT 17" has an Onan engine and needs either a re-Build kit or a replacement Carburetor..
NAPA does not have the Kits (and WOW, the Prices.!)
Could anyone help me find these parts..??
I cannot get the Needle to work properly..it either wants to Flood or Starve to the point it quits.. I tried an Electric fuel pump and it flooded (4lb).. I have worked on the Needle TIP and worked it to a good taper, like it should have been. (Rubber tip).. Any suggestions about another carburetor to use..? This engine is a REAL Powerhouse..I have the Large-Bore Commercial engine block and want to USE it more..!!!
Thanks..! Ron.
kevinsstuff
01-16-2013 07:49:32
 Re: Rebuild Onan Carb..???? in reply to BushogPapa, 01-07-2013 10:12:01
i just ordered a gasket kit for my onan 16hp for my case 446 got the parts from cummins service center. cummins is the place to get your high priced service parts for your onan
ken combs
01-07-2013 15:26:20
I forgot to mention: check your float before ordering parts, and if it is a foam version, order a brass one along with the needle and gaskets. foam + alcohol = frustration!
danc11358
01-07-2013 12:09:57
Hi.I have A Case 446 with A 16 H.P. Onan. Got carb. kit from Gary's place. Good service good price.
danc11358
01-07-2013 16:11:03
 Re: Rebuild Onan Carb..???? in reply to danc11358, 01-07-2013 12:09:57
Gary's Place 1068 E. Hull Rd.Hope Michigan 48628 Tel.989-689-5092.
Harvey 2
01-09-2013 09:31:38
 Re: Rebuild Onan Carb..???? in reply to danc11358, 01-07-2013 16:11:03
Thanks a bunch on the location and phone # for Garys Place.
This is what the forum is all about, people helping one another.
Thanks again;
Harvey 2
01-07-2013 16:00:39
Where is this Garys place ? I would like to buy some parts, if they are reansoble.
Harvey 2
01-07-2013 10:49:38
Parts for Onans have allways been overpriced and they aren't getting any better.
One stop gap measure would be to install a inline fuel shut off and adjust the flow to a trickle,that might work. I bought a Cub Cadet several years ago and wondered why it had two shut offs on it, then I found out the carb always wanted to flood. I installed a new float and adjusted it, that stopped the flooding, wasn't even the needle and seat after all.
ken combs
01-07-2013 10:15:34
Try Onanparts.com.
BushogPapa
01-07-2013 10:39:49
 Re: Rebuild Onan Carb..???? in reply to ken combs, 01-07-2013 10:15:34
Thanks a bunch...!!
This is going to Help..!
Ron.
Billy Shafer
01-07-2013 16:26:27
 Re: Rebuild Onan Carb..???? in reply to BushogPapa, 01-07-2013 10:39:49
Try Max Thompson. Over on Smokstak Onan section. He just bought the inventory of a Onan dealer. He may have a kit.
BushogPapa
01-08-2013 19:32:43
 Re: Rebuild Onan Carb..???? in reply to Billy Shafer, 01-07-2013 16:26:27
Where is "Smokestak"..?? I will look for an "Onan Section"..
Thank you.. Ron..
Billy Shafer
01-13-2013 12:29:32
 Re: Rebuild Onan Carb..???? in reply to BushogPapa, 01-08-2013 19:32:43
It is smokstak.
BushogPapa
01-16-2013 12:45:20
 Re: Rebuild Onan Carb..???? in reply to Billy Shafer, 01-13-2013 12:29:32
Thanks. everyone for this information..!!!
Ron..
