Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: John Deere 322 charging system
jd730gas
01-06-2013 19:31:37
Thank you. It is a 3 cylinder, either a Yanmar or Kawasaki I believe. I suppose it could be dusty and dirty connections because it was really dirty chopping and bagging leaves and worked fine for several hours.
El Toro
01-07-2013 05:25:56
 Re: John Deere 322 charging system in reply to jd730gas, 01-06-2013 19:31:37
You should check with your local JD dealer to see if they will scan a copy of the wiring diagram on your charging system. If it has an alternator you should have a rectifier. It may just be a loose wire or a bad connection. I had a JD 140 that wouldn't charge and it just needed the terminals cleaned on the rectifier. Hal
Copyright © 1997-2015 Yesterday's Tractor Co.
