| Garden Tractors Discussion Forum |
Topic: John Deere 322 charging system
[Return to Forum]
| Author |
[Modern View]
| jd730gas
01-06-2013 08:03:33
173.25.222.168
I have a JD 322 that I really enjoy. Right at the end of leaf collection season my battery charge light came on. Eventually of course when I shut it off to empty bags it would not start. After charging it up it will start and work of course but light is still on and now electric mower clutch will not engage. Where do I start? Alternator/generator; voltage regulator; mower electric clutch; battery or combination? Thank you for any help. |
[Reply] [No Email] | |
| stronics
01-09-2013 14:31:41
207.155.115.88
Re: John Deere 322 charging system in reply to jd730gas, 01-06-2013 08:03:33
| Gentlemen, There are ways to check out the system, get the correct diagram and check it. Does the alternator have 27-35 AC volts? Is it getting to the regulator? Are you getting around 13 or higher volts DC at the battery. David |
| ken combs
01-07-2013 10:17:56
76.254.213.30
| | That uses a small belt driven alternator. Most likely it is the regulator as the alt seldom fail. That is a 3cyl yanmar gas right?? |
| Bob
01-09-2013 07:29:55
64.255.159.192
Re: John Deere 322 charging system in reply to ken combs, 01-07-2013 10:17:56
| IMHO, most common failure with that system is the multiple contact electrical plug between the alternator and rectifier/regulator. |
| El Toro
01-07-2013 05:40:56
108.3.143.30
| Here's a link for troubleshooting your charging circuit. Hal |
| El Toro
01-06-2013 08:44:11
108.3.143.30
|  Which engine do you have? If it's a Kohler it may have a stator that produces Ac voltage and you would also have a rectifier/regulator to convert the AC to DC volts. You can use a volt meter set on AC volts and with the engine at 1/2 throttle or better you can measure the ac output voltage off the stator should be about 30 volts. If that looks ok switch your meter to Dc volts and measure that. Be careful working around that engine. You can measure the DC volts across the battery terminals, should see around 14 volts. If you only have 12 volts your rectifier is probably defective.. Hal |
| jd730gas
01-06-2013 19:31:37
173.25.222.168
Re: John Deere 322 charging system in reply to El Toro, 01-06-2013 08:44:11
| Thank you. It is a 3 cylinder, either a Yanmar or Kawasaki I believe. I suppose it could be dusty and dirty connections because it was really dirty chopping and bagging leaves and worked fine for several hours. |
| El Toro
01-07-2013 05:25:56
108.3.143.30
Re: John Deere 322 charging system in reply to jd730gas, 01-06-2013 19:31:37
| You should check with your local JD dealer to see if they will scan a copy of the wiring diagram on your charging system. If it has an alternator you should have a rectifier. It may just be a loose wire or a bad connection. I had a JD 140 that wouldn't charge and it just needed the terminals cleaned on the rectifier. Hal |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
